Podložky pod RZ a vše kolem
Ahoj, sorry for don't speak Cesky.
Some weeks ago I asked on this forum about if in CZ exist small number plates like in Italy or Swiss... the answer was not :-(
The thread was erased... so, I can't answer in the same post.
I find out one system with "velcro" for make more nice our CZ number plates. Here are the photos of my car.
Before:
After:
I only hope that the glue will be strong.
Before:
After:
Re: Nice number plate for our Alfas
it will be good I think, because number plate on the front is pulled by headwind
Ok. I´ll try to answer you for this...so, no official small size number plates for Czech/Slovak, I´m sorry :/
Second one... I know a few people use glue for metals (you can buy it almost everywhere) or that "Velcro" system looks interesting, but i´ll be worried about my plate, especially in higher speeds etc...
Get us know if it´s strong enough
Re: Podložky pod RZ a vše kolem
At the moment it has endured a month, with snow and low temperatures.
Do you ride on motorways often ?
I had my plate glued with MAMUT Glue... with wich i also glued side skirts on my previous car
It hold safely for years but can there be problem with cleaning area when removing it..
AR 159 SW TBI TI
I know MAMUT Glue, its very famous in CZ.
This Velcro system says that is glue for cars and plate numbers. So, I hope that they think about how to remove without problems from the car.
Yeah, but one you put MAMUT glue, you´ve no chance to take it down without damaging bumper
Ja jsem spz prilepil oboustranou paskou. Osobne jsem pouzil Akryl gel AFT.
Uz predtim jsem ji pouzival v aute (dascam, prilepeni hid balastu) a v domacnosti (napr 2 roky drzi velke a tezke zrcadlo 1,5m x 2m) a neni s tim zadny problem.
Sice na prvni pohled to vypada ze nic neudrzi (jak je gelova tak se velmi snadno roztahuje), ale jak to prilepis a pritlacis tak musis vynalozit velmi velkou silu na odtrhnuti. A navic to nijak neposkozuje spojovane materialy a gel pohlcuje cast vibraci.
I have a number plate attached with a double-sided tape. I personally used an acrylic gel tape AFT.
I've used it before in my car (dashcam, hid xenon balast) and at home (for example, 2 years holding a heavy mirror 1.5m x 2m) and there is no problem with it.
Although at first glance it seems to hold nothing. Because gel is very easy to stretch, but as you stick it and press it hard, you have to have a very strong force to tear it off. And, moreover, it does not harm the connected materials and the gel absorbs the vibration.
Opel Corsa 1.4T 74KW 2018
Glue? The screw never die
159SW 2.4JTDM /2008/ 1755kg
Perfect!!! I like your solution.romanc píše: ↑23.2.2018, pát 23:22 Ja jsem spz prilepil oboustranou paskou. Osobne jsem pouzil Akryl gel AFT.
Wow, my wife say me that this is illegal on CZ.
In my country (Catalonia), all cars use screws for number plates. This is the reason why I tried find another solution with glue/velcro.
- MikeC
I really doubt screw is more ilegal then taping/glueing the plates to the bumber
May be as the screw is integrality disruption of plate and this is (at least in Slovakia) illegal.
Přímo v návodu značky je uvedeno, že lze použít podložku nebo šrouby.
Screws are alowed here.
WTF? místo obázku tam skáče nějaká reklama
Naposledy upravil(a) Adamsquare dne 2.3.2018, pát 13:51, celkem upraveno 1 x.
Jakoze me muzou vyhodit na STK kdyz mam prisroubovany SPZtky?
Srouby muzes pouzit, ale nesmi jakkoliv zasahovat do znaku, vlajky a textu. Navic musi byt zakryty ci zabarveny aby nebyly videt. Co neni povoleno jsou nyty.
Screws can be used but must not interfere with the character, flag and text. Moreover, they must be covered or tinted to not be visible. Rivets are forbidden.
Máme na velkejch značky normálně přišroubovaný, auta, vleky i návěsy, klasickejma vrutama bez nějakých krytek, STK děláme každej rok, a žádnej problém.
Very thanks for the info guys.
§123 zákona o cestnej premávke
(4) Držiteľ vozidla je povinný vydanú tabuľku s evidenčným číslom bezodkladne pripevniť na vozidlo. Tabuľka s evidenčným číslom nesmie byť pripevnená spôsobom, ktorý narušuje jej celistvosť a znemožňuje jej čitateľnosť alebo identifikáciu. Ak boli vozidlu vydané dve tabuľky s evidenčným číslom, držiteľ vozidla je povinný bezodkladne pripevniť na vozidlo obe tabuľky.
- yetyGT
Jakub_mt píše: ↑4.5.2018, pát 15:04 §123 zákona o cestnej premávke
Uživatelé prohlížející si toto fórum: Žádní registrovaní uživatelé a 20 hostů
