generátor zvuku motoru (Giulia/Stelvio)
Příspěvek od Kubas » 13.2.2020, čtv 21:52
zde. píše:
13.2.2020, čtv 20:36
Nedalo mi to a něco jsem pohledal. Jestli jsem hledal dobře, tak stelvio to má od začátku a giulia od MY2019. Fakt ostuda, jsem netušil, že alfa tuhle naprosto nepochopitelnou debilitu taky zavedla.
Theory of Operation
The Engine Sound Enhancement Module (ESEM) / (ANC) transmits a tuning sound through the Center I/P Speaker, to reproduce the engine sound in the passenger compartment. The synthesized sound uses engine noise, vehicle speed, engine torque and accelerator position to reproduce the most correct sound in the passenger compartment to enhance the driving experience. The sound is processed according to the driving mode selector position. The system consists of a Shaker Microphone, the ESEM and the Center I/P Speaker.
The Shaker Microphone is a magnetic-dynamic transducer located on the engine intake manifold. It picks up intake air vibrations and translates them into electric pulses, which are sent to the ESEM.
The ESEM receives data from the microphone; then processes, amplifies, and sends the audio signal to the Center I/P Speaker. The ESEM also receives information about engine load, engine rpm and vehicle speed from the BCM. The sound is projected by the speaker located in the center of the dashboard. The ESEM receives power from the rear PDC.
The Center I/P Speaker is connected to the ESEM instead of the amplifier. There are two types of speakers for the ESEM: basic and top sound system level. The Center I/P Speaker is present in both sound systems and is used for the ESEM only, regardless of the sound system level (basic or top).
Spider 2000 (1975), 90 V6 QO (1984), Giulia Super 2000 Track car project (1975) + občas Giulia 2.0T 200CV (2017)
Re: generátor zvuku motoru (Giulia/Stelvio)
Příspěvek od Kubas » 13.2.2020, čtv 21:53
zajímalo by mě jestli existuje nějaká studie že tohle někdo v Alfě Romeo chce.... nebo jestli to tam narvali jen proto, že "to tak dělají všichni".... :roll:
kenjiro
Příspěvek od kenjiro » 13.2.2020, čtv 22:10
Od zacatku nechapu, proc tam nedali nejaky poradny vyfuk treba i s elektricky ovladanou klapkou. Misto toho ten mdly zvuk dohani elektronickyma kravinama :roll:
Giulia Super 2.0T
venca43
Příspěvek od venca43 » 14.2.2020, pát 06:23
Já tuhle skvostnou nadstandardní výbavu nechápu teda vůbec. Mně nevadí , že to auto nemá zvuk ale měli to udělat aspoň vypínatelný.
Giulia veloce
venca43
Příspěvek od venca43 » 14.2.2020, pát 06:30
Neumí ty zvuky někdo šikovnej deaktivovat nebo tak něco?
Giulia veloce
Příspěvek od Kubas » 14.2.2020, pát 07:35
chce se to podívat na zahraniční fóra.... možná se k tomu nějak dostanu....
kenjiro
Příspěvek od kenjiro » 14.2.2020, pát 08:50
Mrknu pres den na multiecuscan jestli tam neni moznost. Ale MY2018 a dal maji SG, takze bude potreba bypass. Je to hodne otravny?
Giulia Super 2.0T
petrAR156
Příspěvek od petrAR156 » 14.2.2020, pát 09:56
Možná by stačilo odpojit čidlo (ten mikrofon, nebo mikrofony, pokud jich tam bude víc). Pokud je to naprogramované košér, tak by se dopočítávání zvuku mělo vypnout.
venca43
Příspěvek od venca43 » 14.2.2020, pát 11:57
Jako vyloženě otravný to není asi to zní i tak nějak “přirozeně”. Spíš mě překvapilo , že to tam vůbec je. Já jsem z toho auta pořád nadšenej a určitě ho kvůli tomu zvuku prodávat nebudu 😃. Ještě jsem si ani nespároval telefon a vpodstatě nic nenastavil takže nějakej zvuk z repráků mě nerozhodí.
Giulia veloce
Příspěvek od zde. » 14.2.2020, pát 12:05
petrAR156 píše:
Aby to nehodilo chybu a nouzák :-)
EDIT: To bude ono :smt102 Ale o nouzáku nic nepíšou, to musí někdo testnout :D
Code:
B140E-13
Definition:
Engine Shaker Speaker Input - Circuit Open
Description:
Module is powered. System voltage is greater than 9 volts and less than 16 volts.
Failure Type:
Circuit Open
This sub type is used for failures, where the control module determines an open circuit via lack of bias voltage, low current flow, no change in the state of an input in response to an output, etc.
petrAR156
Příspěvek od petrAR156 » 14.2.2020, pát 12:20
Tak samo, z pohledu systému chybějící/nefunkční čidlo chyba je, tak bude mít i dg ḱód. Jde o to jak se to zachová dál, tedy jak je tato chyba systémem dál zpracována. Ale tohle vyzkoušet asi nebude nic tak komplikovaného.
swoop01
Příspěvek od swoop01 » 14.2.2020, pát 16:40
Resite kraviny...
Vagonka, Nuninka, Bestie
venca43
Příspěvek od venca43 » 17.2.2020, pon 20:32
Asi tam ty generátory dávaj aby se pisálkům líbilo jakej to má zvuk.Potvrzuje to ,že Stelvia to maj všechny a Giu 2018 ještě ne.
Prej nemá zvuk a chuť po otáčkach chtělo by to motor ze Supa... To je ubohost
https://www.autickar.cz/clanek/alfa-rom ... nim-miste/
citace:
"V tomto případě musím bohužel poněkud hereticky přiznat, že jsme s Danem zálibně teoretizovali nad myšlenkou, jak by to pod kapotou Giulie Veloce slušelo agregátu 2.0 TSI z paralelně testovaného Superbu…
Ne snad že by byl dvoulitr od Alfy špatný. Jen mu nějak chybí ten správný zvuk – což je zvláště pozoruhodné vzhledem k faktu, že úplně stejný agregát pod kapotou Stelvia zní opravdu dobře (zdá se, že je na Stelviu vidět, že bylo představeno později a některé věci se “stihly dodělat”). A co je možná ještě horší, nemá chuť po otáčkách."
Giulia veloce
Ales159
Příspěvek od Ales159 » 17.2.2020, pon 20:49
venca43 píše:
citace:
Giulia 18 už to v ceníku měla, dříve si nejsem jistý, ale 18 už ano
Alfa Romeo Giulia Veloce 2,0T
EX- Alfa 159 2,4 JTDm
Fiat 500 1,2 Lounge
Příspěvek od Hampice » 20.2.2020, čtv 08:12
Hlavně že v tom superbu repráček určitě není … To jsou fakt klauni....
Alfa Romeo 156 2.0 TS (2000) spící vrána
Fiat Bravo 1.4 T-Jet 16V Sport (2008)
Fiat Grande Punto 1.4 Dynamic (2008)
Zpět na „Giulia“
